Overheating
Discussion in 'Liberty' started by Body Stacker 0341, Jul 24, 2019.
  1. Jul 24, 2019 at 4:31 PM
    Body Stacker 0341
    Body Stacker 0341 [OP] New Member
    Mike
    2003 Jeep Liberty Sport
    I need to pick yalls brain. I have replaced the Thermostat, radiator, radiator hoses, condenser, coolant temperature sensor, and water pump on my 2003 Liberty and she is still overheating. I now have no other ideas. Please help
  2. Jul 24, 2019 at 5:05 PM
    Welcome @Body Stacker 0341 ....are the cooling fans operating as the jeep over heats? What's your procedure as the jeep overheats on the road? Proper coolant mix? Clogged passages? Just some thoughts.
  3. Jul 24, 2019 at 6:12 PM
    Body Stacker 0341
    Mike
  4. Jul 25, 2019 at 7:28 AM
    :jeepwave:greetings ...... welcome to the forum
    let look at this its overheating - need some info,
    indication is only the temp gauge's slow rise to high temp or just boiling over shortly after start up?
    How do you know there are no codes?
    the fans DO work?
    This is a 3.7 wiht an automatic?
    Why did you change condenser?
    parts are NEW- radiator, water pump, thermostat?
    Any evidence of oil in coolant of coolant in oil?
    Sorry for quiz but I need to get the BIG picture, as you suggest all is in good order yet no cooling. :confused:
  5. Jul 25, 2019 at 2:19 PM
    How about a flush out for the engine block?
