P0128 cause the AC not to work?
Discussion in 'Wrangler JK (2007-2017)' started by Maverick24, Jun 19, 2018.
  1. Jun 19, 2018 at 7:17 AM
    Maverick24
    Maverick24 [OP] New Member
    2012 metallic hunter green wrangler
    will a p0128 code cause the ac not to work
  2. Jun 19, 2018 at 8:09 AM
    P0128 - Coolant Temperature Below Thermostat Regulating Temperature
    A search is indicating that it could definitely affect the AC
  3. Jun 19, 2018 at 8:10 AM
    Maverick24
    That code is popping and the ac won’t turn on
  4. Jun 19, 2018 at 12:54 PM
    Why not address the code?
    There are NO other codes -
    P0128-THERMOSTAT RATIONALITY - coolant level in radiator not tank, thermostat issue, AAT issue
    Many codes will effect other systems - a protection logic... Why you always SCAN.
  5. Jun 19, 2018 at 2:17 PM
    Maverick24
    I was curious but I am addressing the code damn really
  6. Jun 19, 2018 at 2:26 PM
    AC is a priority!!
    As I said check fluid level - replace thermostat - do not use lower rating T'stat!
    Do you have a Ambient temp sensor? in case the above does not solve issue...
  7. Jun 24, 2018 at 8:51 AM
    Maverick24
    Replaced the temp sensor this morning reset the computer and now all is well. A/C is also back to working
  8. Jun 24, 2018 at 9:59 AM
    Great to hear!
