P0206 - Get this code, gas smell, cylinder 6 misfire from time to time
Discussion in 'Cherokee' started by Rookie, Dec 14, 2017.
  1. Dec 14, 2017 at 2:56 PM
    Rookie
    Rookie [OP] New Member
    Doug
    2004 Jeep Cherokee Laredo- Inline 6
    I am a rookie at working on my jeep, but I wanted to get some input on this issue. From time to time I get a really strong gas smell, shaking, and nasty looking exhaust on cold starts. Can usually just re-start and the issue goes away. Can it be as simple as replacing the fuel injector for the cylinder six? Seems like to me it might be in the wiring harness? Has anyone else had this problem?
  2. Dec 14, 2017 at 4:08 PM
    Welcome to the site! Just noticed the code in the title. That code is triggered most times by the #6 fuel injector being the cause. Check the plug to the injector, swap the injector with another, and see if the code changes, or replace the injector.
  3. Dec 14, 2017 at 6:56 PM
    Welcome to the forum Rookie.
  4. Dec 14, 2017 at 8:06 PM
    Welcome! The fuel injector circuit for cylinder 6 is a common cause for P0206 so get it checked out.
