P0302 remains after attempted repair
Discussion in 'Wrangler JK (2007-2017)' started by meatman69, Apr 15, 2019.
  1. Apr 15, 2019 at 11:58 PM
    meatman69
    meatman69 [OP] New Member
    2014 jeep wrangler 3.6
    hello this is randy last year I bought a 2014 jeep wrangler sport 2 door with a 3.6 engine ive done a lot of upgrades on it,but now it has a code P0302. I've replaced the coil boot and sparkplug still has a code. also I need to say it has less than 50,000 on it anyone have some help please.
    TJ_abuser likes this.
  2. Apr 16, 2019 at 3:40 AM
    thats a common code P0302 a misfire could be either ignition, fuel, mechanical.
    1st - counter intuitive #2 cylinder is driver side front plug. Were you on correct cylinder?
    Were there any other codes - did you use a scanner?
    You changed just the 1 spark plug? same BRAND and #?
    This is a COP (coil over plug) did you check spark at plug?
    Add a can of 'seafoam' or 'techron' fuel treatment - will clean a gummed up injector.
    After confirming with a scanner, doublechecking #2 spark, next a compression test.
    PS: lots of 'upgrades' no powertrain (engine) mods- none?
    OFFGRID, TJ_abuser and aggrex like this.
  3. Apr 16, 2019 at 5:12 AM
    Welcome from Texas there are some smart people on here someone will steer you in the right direction at least.
  4. Apr 16, 2019 at 5:32 AM
    Hello Randy, welcome from Oklahoma.
  5. Apr 16, 2019 at 5:34 AM
    Pun intended? :rofl:
    TJ_abuser[QUOTED] likes this.
  6. Apr 16, 2019 at 5:37 AM
  7. Apr 16, 2019 at 9:02 AM
    meatman69
  8. Apr 16, 2019 at 9:04 AM
    meatman69
    good input I was thanking 2 cylinder was passenger front lol
  9. Apr 16, 2019 at 9:26 AM
    Harleymick
    Harleymick Well-Known Member
    Mick
    1999 Jeep Wrangler Sahara
    If all else fails, pull the CPS and clean the plug in thoroughly with spray electronics cleaner. The last time my engine started sputtering and I received a code I unplugged all of the sensors, cleaned them and plugged them back together. I don't know which one fixed it but it doesn't really matter. I worked part time at O'Reilly's Auto Parts and sold a lot of new sensors when the old one simply needed cleaned.
  10. Apr 16, 2019 at 12:15 PM
    for future reference
    OFFGRID likes this.
