P1682 code
Discussion in 'General Jeep Discussion' started by JeepMafiaMama, Dec 20, 2019.
  1. Dec 20, 2019 at 12:33 PM
    JeepMafiaMama
    JeepMafiaMama [OP] Well-Known Member
    Lisa
    Central ny
    This morning I got to work and my check gauges light was on in zj. The battery gauge was zero!! But she was running like a champ. Leaving work it did not come back on and there was no issue nor when I stopped at the store. Was just wondering if the -8 temperature outside could have tripped the check gauges light?
  2. Dec 20, 2019 at 12:57 PM
    When was the last time the alternator was replaced?
    The next time it acts up, if you can stop and put a multimeter on the battery and check the voltage. It should be about 13.8-14.3 volts.
    Then try tapping on the alternator case and see if the voltage comes back up.
    From reading online it likely needs an alternator.
  3. Dec 20, 2019 at 1:47 PM
    Swing by the local Advance/Autozone for free battery+alternator test. Make a better decision after getting some analysis. Cold temps can give you a sign/clue about your battery condition and have an affect on batteries especially ones with a few years.
  4. Dec 22, 2019 at 12:41 PM
    JeepMafiaMama
    Lisa
    Central ny
    Bad battery!! Had the guy at Napa test it. Jus had it tested this fall and it was fine...However its cold as shit round here these days. Thank ya for your input here guys. :)
