PCV Valve hose routing 1978 CJ5 258
Discussion in 'CJ' started by Rusteze, Sep 13, 2021.
  1. Sep 13, 2021 at 8:41 PM
    Rusteze
    Rusteze [OP] New Member
    1978 CJ5 258 3 spd
    Basic
    Hey everyone I'm new to this Forum. I was able to buy back back my 1978 CJ5 258 3 spd. The Wife and I dated in this CJ 30 years ago! The owners put a Mr. Gasket chrome breather in the PCV grommet on the valve cover, I order a OE PCV and it has a "T" at the top, 2 hoses. One goes to the air cleaner, where does the smaller diameter hose go? It's a one barrel Carter.
  2. Sep 14, 2021 at 12:00 AM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    I think that the PCV connects to full manifold vacuum below the carburetor throttle plate and T's to the charcoal cannister vacuum. A separate vent line goes from valve cover to the filter housing.
    Hopefully someone with a CJ on the forum can verify the connections, been a while since I've worked on one.
  3. Sep 14, 2021 at 10:30 AM
    Rusteze
    1978 CJ5 258 3 spd
    Basic
    Thank you.
