Please help no Park, no drive, and no reverse... 2006 Jeep Grand Cherokee Limited
Discussion in 'Grand Cherokee' started by TinyInkognegroT, Sep 1, 2019.
  1. Sep 12, 2019 at 10:22 AM
    #41
    TinyInkognegroT
    So we finally decided to put a transmission dipstick into the transmission and it was bone dry. We added 4 quarts, as asked by the uncle, and we got no luck... No more grinding in reverse, neutral, or drive but there is a grinding in park. My uncle says it isn't enough transmission fluid to get it moving and to buy a couple more quarts to add in and try again ...
  2. Sep 20, 2019 at 11:21 PM
    #42
    pat4x4
    pat4x4 New Member
    you are grinding on park because your transmision is turning, since you went into drive or reverse first. when you put it into gear have someone look underneeth your front output from transfer case is turning. transfercase needs both drive shaft not like older model you cant take it off. if you put your driveshaft back on you will see everything will move and work. i tried to take off my self while i waited for new drive shaft part wanted to drive without it. same as you put it back on everything worked. so fix you driveshaft
  3. Sep 21, 2019 at 10:15 AM
    #43
    Welcome @pat4x4 ...interesting twist in the grinding no drive, park, reverse saga
  4. Sep 22, 2019 at 7:48 PM
    #44
    Unusual intro @pat4x4 . But welcome to the forum. @TinyInkognegroT . How you making out with this issue? My first thought was no fluid.
  5. Sep 23, 2019 at 8:05 AM
    #45
    TinyInkognegroT
    The driveshaft never spinned when I had it in and the problem first occurred. I still have the drive shaft if I need to put it back in and verify that. But the driveshaft wasn't spinning it all
  6. Sep 23, 2019 at 9:06 AM
    #46
    install drive shaft.
  7. Sep 26, 2019 at 5:19 PM
    #47
    TinyInkognegroT
    PHOTO_20190925_201828.jpg PHOTO_20190926_190908.jpg PHOTO_20190926_190937.jpg PHOTO_20190926_191311.jpg
    Good call, looks here as if the front drive shaft is broken on the CV end...
  8. Dec 9, 2020 at 12:46 PM
    #48
    jeeplife
    jeeplife New Member
    2006 Jeep Cherokee 2.8crd automatic
    Hi, Did you finally fix the problem? I’m having exactly the same problem
  9. Aug 15, 2022 at 4:28 AM
    #49
    Animalchin
    Animalchin New Member
    Having this same issue, really hoping someone can clue me in on what the problem ended up being. Was this resolved?
  10. Aug 15, 2022 at 6:27 AM
    #50
    Turned out to be the drive shaft if I'm not mistaken.
    aggrex and Animalchin like this.
  11. Aug 15, 2022 at 8:38 PM
    #51
    Animalchin
    Yep driveshaft it was, replaced it today, thanks for the reply JKBob
