Plug gap
Discussion in 'General Jeep Discussion' started by Adam39601, Mar 4, 2018.
  1. Mar 4, 2018 at 9:38 AM
    Adam39601
    Adam
    2001 jeep wrangler sport
    I've been having a misfire on my Jeep 2001 Wrangler I put it on the diagnostic it said second cylinder misfire what I pulled my plug just check them out and it look like that plug gap gauge was real tight just my question I have I'm not very mechanical on these things but does the gap sometimes if it's wrong cause a misfire and what is the proper gap thank you for the help
  2. Mar 4, 2018 at 7:38 PM
  3. Mar 5, 2018 at 5:58 AM
    How old are the plugs and wires? In need of replacing?
    You could also clear the code and move the injector or the spark plug/wire to a different cylinder and see if the misfire code follows it.
    JKBob 25, aggrex and OFFGRID like this.
  4. Mar 5, 2018 at 3:49 PM
    The premium brands come pre-gapped but should be checked. 0.035 in for the 6 cyl for example.
    Prerunner1982 and JKBob 25 like this.
