Popping noise at idle
Discussion in 'CJ' started by Jaycool47, Jan 27, 2022.
  1. Jan 27, 2022 at 4:46 PM
    Jaycool47
    Jaycool47 [OP] New Member
    Jay
    1983 cj7 limited
    I have a 83 cj7 with a 4.2. It has a popping noise at idle, the only way I can get it to stop is pull the #6 plug wire and it doesn't sound like it's missing but the popping stops. The compression on #6 is 150. I have spark and a new plug so I'm not sure what's going on. Anyone have any ideas? Thanks in advance.
  2. Feb 1, 2022 at 11:28 PM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    Any other symptoms? Is the noise always there, even when the engine is hot or just after cold start up? Any power loss or rough running? Plug wires in good shape?
    150 compression is good so it seems unlikely that you're exhaust valve is burnt or not seating.
    Could just be a small exhaust manifold gasket leak at #6. Might try spraying soapy water on it when engine's cold and see if it blows any bubbles.
  3. Feb 2, 2022 at 7:54 AM
    Jaycool47
    Jay
    1983 cj7 limited
    I don't hear the popping noise while I'm going down the road, just at idle hot or cold. I've messed with the timing a little and didn't seem to change any. I have discovered that my timing chain is really lose so I'm thinking that might be it. But why just the one cylinder?
  4. Feb 2, 2022 at 6:14 PM
    Groundfault
    Tim
    Timing issue would cause missing and backfires on all cylinders.
    Air filter and clogged fuel filter can cause lean or rich condition and popping, once again on all cylinders.
    Possible for a bad spark to cause incomplete detonation in one cylinder. Make sure your plugs gapped right, plug wire is good, check distributor cap for signs of arcing.
    Head gasket leak to outside of cylinder will cause a popping noise, but I doubt you'd have 150 compression reading.
    A blown or cracked exhaust manifold gasket on #6 would cause popping sound and would all but disappear without cylinder detonation on #6.
    I don't know how loud the popping is. Is it really going away at higher rpm or just can't be heard over the road and wind noise. Try slowly opening the throttle manually at the carb to increase rpm while parked and see if it goes away.
    Best of luck. Hope you find cause.
  5. Feb 2, 2022 at 6:30 PM
    Jaycool47
    Jay
    1983 cj7 limited
    Thank you sir I will definitely check those things out, appreciate the help.
  6. Mar 6, 2022 at 8:41 AM
    MTgeezer
    MTgeezer Well-Known Member
    John
    55 CJ 3B
    The AMC 258 is know for exhaust manifold leaks. The first thing I would be checking is the gasket at #6. As above, soapy water when cold.
  7. Nov 9, 2022 at 10:27 PM
    caltexjeeps0436
    caltexjeeps0436 New Member
    cj5
    ground up restoration and mods to compensate for my oscar meyer weiner
    Sticking intake valve can cause it if its popping through carb! ask me how i know! :bananadead:
