Power door locks not working 99 Grand Cherokee Laredo
Discussion in 'Grand Cherokee' started by 911 SUPERVISOR, Aug 15, 2019.
  1. Aug 15, 2019 at 6:06 AM
    911 SUPERVISOR
    911 SUPERVISOR [OP] Member
    Danny
    1999 grand cherokee laredo
    I have a new problem. The electric door locks are not working. Also the dome light is staying on even when you start the engine. And the only window that will roll down is the driver side. Could the problem be in the driver side switch panel. I still have the issue that if either of the passenger side doors are open the windows wont work or the door locks. Also I am unable to locate the door switches for the dome lights.
  2. Aug 15, 2019 at 6:57 AM
    door ajar switches are incorporated in the door latch.
    Is the EVIC indicating a open door?
    Suspect the wiring at door to body connection is issue.
    911 SUPERVISOR[OP] likes this.
  3. Aug 15, 2019 at 8:14 AM
    911 SUPERVISOR
    Danny
    Evic is not showing any open doors.When I open the driver side doors and the hatch it registers them. But it does not register either passenger side door. Also where can I find a wiring schematic with color codes so I will know which wires to look at. Also how do you get that rubber boot out of the way to access the wires easier.
  4. Aug 15, 2019 at 8:22 AM
    you would do your probing inside the door, or remove kick panel.
    I will add diagrams later its a busy day here.
    you could look here - register as a fleet manager but an often used safe library.
    http://www.bbbind.com/tsb-wiring-diagrams/
  5. Aug 15, 2019 at 10:46 AM
    911 SUPERVISOR
    Danny
    AWRENCH THANKS FOR ALL YOUR HELP. i WENT TO THAT SITE AND GOT WIRING DIAGRAMS. i FOUND A TAN WIRE WITH BLK STRIPE ON THE PASSENGER FRT DOOR INSIDE THE RUBBER BOOT THAT HAD BROKEN ALL THE WAY THROUGH. i SPLICED IT AND NOW EVERYTHING WORKS. YOU HAVE BEEN A LIFE SAVER.
    JeepMafiaMama likes this.
