Power locks on 2000 XJ won't always lock.....
Discussion in 'Cherokee' started by Mikeylikesit, Mar 21, 2018.
  1. Mar 21, 2018 at 3:22 PM
    Mikeylikesit
    Mikeylikesit [OP] Member
    starts with an "M"
    2000 Cherokee XJ "Freedom" edition
    anybody know what causes it? It's intermittent. Drivers door, unlocks (all doors) just fine, won't unlock.......except very occasionally. Passenger door unlocks just fine, and locks almost all of the time. I can't seem to see a pattern........thinking voltage but have proved that wrong.
    dirty switches? You would think there would be some consistency......ugh!
  2. Mar 21, 2018 at 4:24 PM
    There could be a wire broken in the harness that goes through the door jam, or a solder joint on one or more of the door lock relays could be broken. The relays are in the passenger side arm rest. You can hit the solder joints with a soldering iron and reset the solder joints.
    My lock work intermittently as well but I can hear the relays clicking. I haven't hit the relays with a soldering iron yet but that is the plan. We shall see.
    Awrench and JKBob 25 like this.
  3. Mar 21, 2018 at 5:04 PM
    Could be a linkage loose in the actuation?
  4. Mar 21, 2018 at 6:16 PM
    Mine had the same issue. Ran into someone in a parkin log one day and we started talking. His XJ had the same issue. Apparently it's an issue as the jeep older. I never opened it up to see what the issue was. But from what I've been told. It is a relay problem. You hit the lock and you can hear it. It's just not doing what it's intended to do. So I tend to agree with Prerunner1982. Id start there.
  5. Mar 22, 2018 at 7:17 AM
  6. Mar 22, 2018 at 7:20 AM
    Mikeylikesit
    starts with an "M"
    thanks for the help guys. It's gonna be a couple weeks before I can pull it in the garage and spend a day with it....but will be sure to report back on what worked, or what didn't.
  7. Mar 22, 2018 at 7:21 PM
  8. May 30, 2018 at 9:54 AM
    Mikeylikesit
    starts with an "M"
    yeah, yeah, but everybody gets it wrong!
    In the commercial, Mikey "HATES" everything! So LIFE cereal must be pretty good, since.......MikeyLikesIt! :D
    BTW........ordered a new switch for the driver's door. Broke the bank at $22 +shipping. Amazon.
