Power steering fluid!!
Discussion in 'General Jeep Discussion' started by aidanmoffatt, Feb 19, 2019.
  1. Feb 19, 2019 at 1:08 AM
    aidanmoffatt
    aidanmoffatt [OP] Jeep novice
    Aidan
    Cornwall, England
    2004 Jeep Cherokee (Liberty) 2.5 CRD Limited KJ
    Can someone please set me straight, I almost wish I never looked into it, so many different opinions on this! My Cherokee booklet says to use mopar atf+4 but so many people say to not use atf, it should be ps fluid only. I’ve just got new pas pipes as mine were corroded and leaking when I bought it a couple of months back. I don’t want to run into the same problem again, any advice/ expert knowledge would be greatly appreciated.
  2. Feb 19, 2019 at 6:27 AM
    Ok friend, the jeep is a KJ model known as a liberty and marketed to third world heathens as a cherokee.
    See if this attachment helps, let us know. 2 important things -
    1) Welcome to the forums - glad to have you :jeepwave:
    B) take nothing seriously - have fun
    JKBob 25 and aidanmoffatt[OP] like this.
  3. Feb 19, 2019 at 8:00 AM
    aidanmoffatt
    Aidan
    Cornwall, England
    Ah I always have trouble finding information on “Cherokee” and wondered why libertys always came up instead. Now I know, so they are the same thing right? That fact sheet concludes that ATF +4 is correct for mine then. Thank you so much for the information, and your time. And thank you for the kind welcome....
    Do you know the quantity I would require if completely draining the power steering system?
  4. Feb 19, 2019 at 8:27 AM
    Welcome @aidanmoffatt ! Owners manual usually state the PS capacity and recommended fluid type but one should be able use the markings found on PS reservoir. Replacement of dirty dark PS fluid has a role in preventing tube corrosion.
  5. Feb 19, 2019 at 8:55 AM
    aidanmoffatt
    Aidan
    Cornwall, England
    I was kind of meaning, if I bought a 1ltr bottle, would it be enough. The good ones are kind of pricey, so I don’t want to buy more than I need to. Thanks anyway, everywhere I look just says, “to fill line” for capacity, so I’m guessing it won’t be a huge amount.
  6. Feb 19, 2019 at 11:44 AM
    Fyi: since the PS lines (pipes) have been replaced you should remove any air in the lines.
  7. Feb 19, 2019 at 7:23 PM
    Welcome to the forum. @aidanmoffatt
    I see your issue has been addressed. Buy 2 bottles. Doesn't hurt to have some on the garage shelf for a top off. Drop the cash. You own a Jeep. It's worth it.
    Harleymick and aidanmoffatt[OP] like this.
  8. Feb 20, 2019 at 6:23 AM
    aidanmoffatt
    Aidan
    Cornwall, England
    Great advice guys, thank you. Haha yeah I agree, only the best for the jeep!!
  9. Feb 20, 2019 at 7:41 AM
    here is a gift form your new friends - let us know if its helpful
  10. Feb 20, 2019 at 8:39 AM
    aidanmoffatt
    Aidan
    Cornwall, England
    Wow that’s great, thanks!! Mines the 2.5 crd but I’m sure most of the info will still apply.
  11. Oct 16, 2021 at 10:51 PM
    J.C.
    J.C. Member
    John
    Complete OME suspension fitted
    You may well find your particular model in here:
    https://www.jeeps.net/threads/manuals.2527/
