Problem with shift light on 99 Wrangler
Discussion in 'Wrangler TJ (1996-2006)' started by Harleymick, Feb 16, 2019.
  1. Feb 16, 2019 at 9:55 PM
    Harleymick
    Harleymick [OP] Well-Known Member
    Mick
    1999 Jeep Wrangler Sahara
    My TJ has an AX 15 5 spd transmission which I recently took out and reinstalled for a new clutch assembly. I notice the shift light keeps telling me to shift to 6th gear, but I don't have one. I'm about ready to simply remove the bulb to the light.
    Is there an easy legitimate fix I am missing?
  2. Feb 16, 2019 at 10:14 PM
    What's the down-side to removing the bulb would be my question as there is no 6th gear. If all systems function correctly after bulb removal I would be elated but not as much as finding that dang seat belt buzzer.
  3. Feb 17, 2019 at 5:10 AM
    The seal belt buzzer is your friend -
    Its there to remind the forgetful TO PUT ON YOUR SEAT BELT!!!
    If it remains on when belt is secured thats another issue worth looking at.
  4. Feb 17, 2019 at 5:48 AM
    Understood! Seat belts are awesome but on some vehicles the buzzer is loud, relentless, persistent, unending and invasive while repositioning the vehicle. Luv the silent flashing reminders from my Toyota.
  5. Feb 17, 2019 at 9:36 AM
    BUZZZZZ think this is da buz, maybe tape?
    FishinSam and aggrex like this.
  6. Feb 17, 2019 at 9:52 AM
    Tape would work great to tone it down.
  7. Feb 17, 2019 at 10:18 AM
    Mick - your upshift light, is driven by the PCM, regearing has the algorithm AFU - speed. RPM. load. Chalk it up as unintended consequences. Upshift masking decal
    FishinSam, JKBob 25 and aggrex like this.
  8. Feb 17, 2019 at 2:40 PM
    Harleymick
    Mick
    Thank you, but I did as advised by removing 12 screws and taking out the offending bulb. The only problem other than 30 minutes time spent was of course the screw I had left over when I was finished! What the hell, nearly everyone could use an extra screw.
  9. Feb 18, 2019 at 5:27 AM
    was at school for Detroit diesel, team did an engine rebuild. Instructor asked for and talked about left over bolts-
    saying always and every class - sure enough we had 2 - :)
  10. Feb 23, 2019 at 6:09 PM
    2" Superlift kit. 315/ 70/17.
    I always seem to have extra bolts. But never any extra "screws". Maybe I'm doing some thing wrong. :cool:
  11. Feb 23, 2019 at 6:25 PM
    Missing bolts means your screwed ;)
    Harleymick [OP] and JKBob 25 like this.
  12. Feb 23, 2019 at 7:01 PM
    Harleymick
    Mick
    Missing screws may mean it's time to bolt! LOL I put new Bestop Trailsomething seats in 'Rhonda' yesterday to replace the worn out Smittybilts I had. The old ones were gray anyway and they called the new ones spice. Judge the color match for yourself, they seem like pretty well made seats.
  13. Feb 23, 2019 at 7:23 PM
    Color looks well coordinated. Nice upgrade.
    Harleymick [OP] likes this.
  14. Mar 13, 2019 at 7:28 PM
    FishinSam
    FishinSam Member
    Alberta, Canada
    1999 Gold TJ Sahara 4.0L
    Same here... usually short one
  15. Mar 14, 2019 at 5:54 AM
    Seats look good. Maybe it's the lighting, or maybe Jeep changed their color coding but that looks too light to be spice. Of course my reference is an 85 Jeep CJ7.
  16. Mar 21, 2019 at 8:50 PM
    Harleymick
    Mick
    When I was looking for new seats I discovered every manufacturer that sold a 'spice' color had a different idea of what it should be. Mine are Bestop and come very close to the dash and console color. Damn they are expensive but it would have cost even more to have them reupholstered.
