Pulling a small travel trailer with my 96 TJ?
Discussion in 'Wrangler TJ (1996-2006)' started by lbr3570, Jul 3, 2021.
  1. Jul 3, 2021 at 5:52 AM
    lbr3570
    lbr3570 [OP] Member
    Big Red '04 TJ Sport
    Looking to get a small travel trailer...scamp/r-pod/little guy... can my 2004 TJ 6-cyl. tow this?
  2. Jul 4, 2021 at 3:38 AM
    PRMCJ
    PRMCJ Member
    MD
    1986 CJ7 Renegade. 258 I6
    Headman headers, 2.5" lift w/ 31" x11.5 BF Goodrich All-terrain
    There are many factors. Your owners manual should be your starting point. This should give you maximum towing weight, allowable tongue weight and gross vehicle weight. You'll also need the GRVW of the trailer (dry weight of the teiler plus its contents). Once the trailer is loaded, you'll need to know the actual tongue weight, and if this exceeds the jeeps allowable togue weight. You'll also have to know the loaded weight of the trailer and the weight of the jeep' s contents (people, dogs, bikes, food, etc). This may sound daunting, but once you have the information for both the traler and the jeep, it's fairly simple. There are LOTS of YouTube videos on the topic.
    Bob, tomrr, lbr3570[OP] and 1 other person like this.
  3. Jul 6, 2021 at 4:04 AM
    lbr3570
    lbr3570 [OP] Member
    Thank you for this- I have been doing my research all weekend- a lot of the newer 4D have GVWR up to 6000, as does most of the Grand Cherokees, and of course pickups, too. Going to look at some trailers- I've seen a lot being pulled by 4Ds.
  4. Jul 6, 2021 at 5:47 AM
    The "small" trailer is key for successful towing with a TJ/JK. Stability on the road, braking and cooling are important while staying within the allowable limits.
    Justanotherjeeper, Bob and LYFZGOOD like this.
  5. Jul 14, 2021 at 4:07 PM
    Justanotherjeeper
    Ontario, Canada
    2024 4xe Rubicon
    Good enough as it is
    Wheelbase is a key parameter for stability that is mostly neglected in owners manuals. A 2 door jk won’t tow much safely. That’s the bottom line. All the added air bags, spring helpers, heavy duty shocks, transmission coolers, heavy duty rads and load range e tires won’t change its short, inherently unstable, wheel base. A gladiator is a better vehicle for this reason alone. So is any 4 door pick up.
    aggrex and lbr3570[OP] like this.
  6. Jul 14, 2021 at 4:16 PM
    lbr3570
    lbr3570 [OP] Member
    Funny you should mention a gladiator...I decided to upgrade and mine will be here in 6-8 weeks. I truly love my TJ, but I need something to tow safely with. So...Big Red is for sale... spread the word!
