Rattling sound after reaching operating temp
Discussion in 'Wrangler TJ (1996-2006)' started by XAustinCooperX, Jun 7, 2018.
  1. Jun 7, 2018 at 4:15 PM
    XAustinCooperX
    XAustinCooperX [OP] Active Member
    Austin
    Nebraska
    2005 Jeep Wrangler X 4.0L
    So I wanted to get some thoughts on this issue that's been happening since an accident I got into a couple months ago.
    Lady hit the front driver side of the wrangler and was taken to a dealership (which im NEVER doing again) to get looked at and repaired.
    After the 4th time looking at it after they "fixed" it everything seemed right finally until I got to my neighborhood and started hearing a rattling sound every time I started slowing down to come to a stop. I can't really hear it while accelerating, but when I start to hit the brakes and reach around 25mph that's when you can hear it. To me it sounds like it's coming from the drivers side where the lady hit
    Also makes the noise even if I don't use the brakes and let it gradually slow down
    Took it back to the body shop and told them about the issue. They looked at it and said my rear end axle shaft on the passenger side was bad, along with the rear main seal...
    Insurance won't cover it so I started getting things ready and started taking the wheel off and there is no sign of a bad axle shaft
    Things we already trouble shooted:
    -Checked all the axles, all good.
    - checked routers and brake pads, also all good.
    Brake lines are kinds loose and the clips won't stay in the frame (so I'm waiting to get those in the mail and correct those)
    -used the grease gun on the ball joints and tie rod areas .
    I'm really not sure what else to look at
    Today it sounded worse after driving for about 30 mins total got out of the jeep and started hearing another kind of rattling sound from underneath near the oil pain area.. checked fluids and those are great
    What are your thoughts on what this could be ?
  2. Jun 7, 2018 at 4:52 PM
    Any chance it's the cat heat shields?
  3. Jun 7, 2018 at 4:52 PM
    XAustinCooperX
    Austin
    Nebraska
    I will add that to my list lol I'll keep you posted
  4. Jun 13, 2018 at 3:15 AM
    boondoc89 Well-Known Member
    I had to reweld the cat shields on my rig too. They made the same rattling noise doing the same thing. A couple little tack welds and it quit doing it
  5. Jun 13, 2018 at 3:27 PM
    Drd88
    Drd88 Active Member
    Dan
    Silver creek new york
    79 cj 5/2000 wrangler
    360amc Borg Warner t-18 trans
    Fan shroud loose cracked
  6. Jun 14, 2018 at 11:59 AM
    XAustinCooperX
    Austin
    Nebraska
    So I've done some digging around and seen some pretty cheap fixes for the heat shield. I'll knock that out this weekend and letcha know !
    As for the fan, I'll check, but I think we eliminated the radiator so far, doesn't hurt to look
  7. Jun 14, 2018 at 1:37 PM
    One inexpensive quick trick is to use stainless steel band clamp(s) around the loose heat shields to stop the rattling or until they fall off.
    XAustinCooperX[OP] likes this.
