Rear disc conversation emergency brake question
Discussion in 'Wrangler YJ (1986-1995)' started by Little red 91, Jun 22, 2021.
  1. Jun 22, 2021 at 8:16 AM
    Little red 91
    Little red 91 [OP] New Member
    Michael
    Pleasant hill Oregon
    1991 red yj
    4"lift ,axle swap,duel battery box,inverter, under hood compressor
    Im trying to finish up my 8.8 axle swap&disc brake conversion. Whats everyone doing with the emergency brake set up? Are you using the drum type e-brake? How about a hydraulic brake lock?
  2. Jul 5, 2021 at 2:12 AM
    Groundfault
    Groundfault Well-Known Member
    Tim
    87 Wrangler, kind of...
    Check into the High Angle Driveline emergency brake kits at https://www.highangledriveline.com/products.html
    They mount on driveline after transfer case. I haven't gotten around to one yet, but plan to do a hand brake on floor left of drivers seat with cable to high angle disc. I have a 14 bolt rear with discs and I've removed the cable and factory e-brake pedal. If your in 4wd, the high angle setup will lock both front and rear by stopping driveshaft rotation.
    Another option the Eldorado calipers with the built in parking brake lever. Lugnut4x4 sells kits that are in the $350 range depending on optional adds like brake pads. There are also videos online if you want to fab your own and hit the salvage yard for Eldorado calipers.
