Rear Wiper
Discussion in 'Wrangler JK (2007-2017)' started by w1lso, Oct 16, 2017.
  1. Oct 16, 2017 at 8:56 PM
    w1lso
    w1lso [OP] Member
    Matt
    2012 Red Jeep Wrangler Unlimited Sport
    Steel Fender Flares, Warn Stubby Bumper, 35's Toyo ATII Extreme.
    What up Jeepers? So I just put my hard top back on for the Fall and Winter Seasons and now the rear wiper is not working. So not sure if it's the wiring harness or the motor and also if you try to turn it on the radio skips. ??? Anyone ever had this problem?
  2. Oct 16, 2017 at 8:59 PM
    Radio skips? What do you mean by this?
  3. Oct 16, 2017 at 9:07 PM
    Not sure how the radio is connected to your wiper problem but if the HT has been off all summer the wiring harness to the rr wiper may have been crushed, kinked or damaged in some manner. Get a multimeter to test the wires while operating the wiper switches. Check the ground for bad connections or short. Wiper motor should be checked to verify its not the issue.
  4. Oct 16, 2017 at 9:21 PM
    w1lso
    w1lso [OP] Member
    Matt
    While I was trying to get the wiper to work the radio kept pausing/skipping and I was thinking to myself well now my radio is jacked up. So I left it alone for maybe 10 mins and then tried the wiper again and it still wasn't working and then I got to thinking that every time I tried the wiper the radio skipped so sure nough every time I turn the wiper on the radio skips, every single time, so I'm not sure how that's tied in together.
  5. Oct 17, 2017 at 7:02 AM
    Sounds like you could have a wire grounding out on the body. When you put the top back on is there any chance you pinched any wires with a screw or bolt or nut or between the top and body? The Wiper worked when you took the top off Right?
  6. Oct 17, 2017 at 7:33 PM
    w1lso
    w1lso [OP] Member
    Matt
    That’s possible, I will check. Yes, the wiper worked fine when I took it off and stored it for a couple months.
  7. Oct 19, 2017 at 7:00 AM
    w1lso
    w1lso [OP] Member
    Matt
    Well, I unhooked the connector to the motor and blew it out and wiped some residue off and hooked it back up and it works fine. So looks like it wasn’t getting a connection, thank goodness!
  8. Oct 26, 2017 at 4:07 PM
    Offroad798
    Offroad798 Well-Known Member
    Florida
    2015 Rubicon
    Here is what I use on connections. After cleaning them I put this on to help electrical connection and keep out water and crud. Just my two cents worth....LOL
