Removing Rust from Bolts
Discussion in 'Detailing' started by YzJeep713, May 29, 2018.
What can I use or what can I do to Remove the Rust from the Bolt’s holding the Plastic fender
  1. Something that won’t mess with the plastic or paint
    1 vote(s)
    100.0%
  2. Without removing the bolts from the fender
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. May 29, 2018 at 3:21 PM
    YzJeep713
    YzJeep713 [OP] New Member
    2009 Jeep Wrangler Unlimited X
  2. May 29, 2018 at 5:18 PM
    Welcome aboard! I would swap out the washers, with some Nylon ones. That should help prevent the rust from forming.
    YzJeep713[OP] likes this.
  3. May 29, 2018 at 5:21 PM
    Welcome! Stainless steel fasteners would be my choice if painting the bolt/washers fails.
    (edit spelling)
  4. May 30, 2018 at 7:09 AM
    You do not want to remove them or I guess use spray paint, worried about overspray.
    tedious BUT try useing your boyfriends nail polish and paint them, clear coat will hide alot.
    Easiest would be 1 x 1 remove replace.
  5. May 30, 2018 at 7:36 AM
    Whomever's nail polish or not, removal of the fastener then sanding the rust>then priming/painting/coating will delay/stop the rust. Stainless steel bolts+washers in highly visible areas work great and won't rust as easily.
    OFFGRID and chris4x4 like this.
  6. May 30, 2018 at 9:21 AM
    WTF?
  7. May 30, 2018 at 10:19 AM
    YzJeep713
    Thank You I’m gonna swap them out for some Black Nylon washers...
  8. May 30, 2018 at 1:23 PM
    do the bolts 1x1 -- nothing should move and create a visible line...
