Replaced various parts and still overheating on inclines
Discussion in 'Wrangler JK (2007-2017)' started by Cbass011, May 10, 2021.
  1. May 10, 2021 at 6:13 PM
    Cbass011
    Cbass011 [OP] New Member
    Chris.
    2016 wrangler
    3" lift on 35
    2016 wrangler with a 3" lift running 35. Around town all is good. Start to climb medium inclines it start to get hot. Gauge goes to about 3/4. Took it to the dealership. They replace the radiator and cap. Flushed the engine. They have replace both heads and gaskets. It is now back at the dealership with the same issue. Anybody have the same issue or give some advice.
    Thanks in advance.
  2. May 11, 2021 at 5:17 AM
    Sounds like an air flow issue...got a big obstruction or winch up front? Thermostat working properly and correct replacement? Correct type of coolant used during ownership? Check the relays to the electric fans and make sure they work at high temps or with a/c on.
