Replacing headlight assembly
Discussion in 'Grand Cherokee' started by Jinjerlynn, Feb 5, 2026.
  1. Feb 5, 2026 at 8:09 PM
    Jinjerlynn
    Jinjerlynn [OP] New Member
    Jeanna
    1997 Grand Cherokee Limited
    I am trying to change the headlight assembly on my Jeep, are there any suggestions on how to do this?
  2. Feb 6, 2026 at 8:12 AM
    Summary
    To change the headlight assembly on a 1997 Jeep Grand Cherokee Limited, follow these steps:
    1. Prepare the Vehicle
    • Ensure the vehicle is parked on a flat surface and the engine is off.
    • Disconnect the battery to avoid any electrical issues.
    2. Remove the Old Assembly
    • Locate the screws or clips securing the headlight assembly.
    • Carefully remove these fasteners using a screwdriver or appropriate tool.
    • Gently pull the headlight assembly out from the front of the vehicle.
    3. Disconnect Wiring
    • Unplug the wiring harness connected to the back of the headlight assembly.
    • If applicable, remove the bulb from the old assembly.
    4. Install the New Assembly
    • Connect the wiring harness to the new headlight assembly.
    • Insert the new assembly into the housing and secure it with screws or clips.
    5. Reconnect the Battery
    • Once everything is secured, reconnect the battery.
    • Test the new headlight to ensure it functions properly.
    For detailed visual guidance, consider watching instructional videos or checking comprehensive guides available online
  3. Mar 30, 2026 at 8:38 AM
    jtmcculloch
    jtmcculloch New Member
    Jim
    2014 Grand Cherokee
    above poster forgot to mention that on the Grand Cherokee you have to remove the front bumper cover
