Right front dives down when making left hand turns
Discussion in 'Suspension' started by derkeele, Feb 16, 2026.
  1. Feb 16, 2026 at 7:45 PM
    derkeele
    derkeele [OP] New Member
    96 xj
    I run a 96 xj, replaced ball joints wheel bearing shocks coil springs tie rod and drag link upgrade.
    sway bar bushings, upper and lower control arms. you get the picture, I noticed couple weeks ago then I make a left hand turn the right front seems to dive down quite a bit more than than when turning right. thought maybe back shock so replaced that and still doing it/ any suggestions
  2. Feb 17, 2026 at 6:46 PM
    Replaced with OEM suspension parts or lift kit?, alignment?, bolts/nuts torqued to specs?, same-size tires? that’s it for now
  3. Feb 17, 2026 at 7:50 PM
    derkeele
    96 xj
    31" tires, adjustable short arm kit, folbrook auto did alignment they specialize in 4x4. All nuts torqued to spec. Just started two weeks ago before that it was fine. all the work was done about a year ago minus alignment had that done 3 months back
