Rubicon dips to the right going over bumps
Discussion in 'Wrangler JL (2018+)' started by John-John, Apr 26, 2020.
  1. Apr 26, 2020 at 10:26 AM
    John-John
    John-John [OP] New Member
    John
    2018 JL Rubicon
    2" Mopar lift with fox shocks
    I first installed a 4" Superlift and got it aligned as the manufacture said. The alignment shop added a steering stabilizer and a Rubicon express track bar. I was never happy with the lift because if I went over a bump the right side would dip more then left and pull to one side. I contacted the Superlift people and had no resolution to my issue. I since have removed the Superlift and installed a 2" Mopar lift with the fox shocks. It drives completely different but i still have the dipping issue. Which is now making me wonder if the issue is the aftermarket track bar. Has anyone come across this issue?
  2. Apr 27, 2020 at 9:10 AM
    Welcome! Not sure what would cause this, but hopefully someone can chime in with an idea.
