Runs very rough
Discussion in 'Wrangler YJ (1986-1995)' started by BKM, Mar 25, 2019.
  1. Mar 25, 2019 at 10:07 AM
    BKM
    BKM [OP] New Member
    Brian
    1989 wrangler
    Stock
    Hello. Wondering if anyone can help. I recently purchased a 1989 wrangler with a 4.2L engine. The jeep was sitting for 5 years. I got it home and flushed the fuel lines and added fresh fuel. Replaced all filters and did a complete tune up. Jeep ran perfect for 2 days. Day 3 it had problems starting. When it started it ran very rough and would not rev up. I did pull the muffler as it was bad. Any suggestions on what to check or look for would be appreciated.
  2. Mar 25, 2019 at 11:40 AM
    Did you happen to drop the tank and take a gander at the inside of the tank? Could be crap in there that found it's way to the fuel pump and is clogging up most of the pump.
    Also Brian, welcome from Oklahoma.
  3. Mar 25, 2019 at 12:00 PM
    Was going to say what the okey beat me too. Oh yeah and welcome from Texas
  4. Mar 25, 2019 at 12:01 PM
    Welcome @BKM . After sitting for 5 years rubber hoses, seals or gaskets may have deteriorated and any residual fuel in the tank should have been removed. Great that you got it running so that's a positive sign. As mentioned already suspect gummed up fuel pump, filter and/or carb if applicable.
