Sahara/Rubicon
Discussion in 'Wrangler TJ (1996-2006)' started by aluminations, Nov 23, 2018.
  1. Nov 23, 2018 at 6:57 PM
    aluminations
    aluminations [OP] Member
    Dan
    98 Sahara
    Can this be? I recently purchased a 98 Sahara. The hood has Rubicon on it. Is this a decal placed by previous owner or is it legit? If legit what should i look for to confirm?
    Thanks
  2. Nov 23, 2018 at 6:57 PM
    Pic of the hood?
  3. Nov 23, 2018 at 7:37 PM
    Welcome! Primary differences found on the Rubicon are the lockers, sway bar disconnect, 4:1 transfer case. Some jeepers like to build their own and can make the Sport or Sahara equal or exceed a stock Rubicon.
    Your Sahara could just have a Rubicon sticker or a replacement hood off a Rubi and hopefully priced accordingly. Regardless it's a Jeep Wrangler and is waiting for your personal build. Pics of the jeep.
    JKBob 25, TJ_abuser and OFFGRID like this.
  4. Nov 23, 2018 at 7:38 PM
    The Rubicon has a front Dana 44, locking differentials both front and rear controlled by switches in the cab, an electronic front swaybar disconnect also controlled by a switch in the cab, and a 4:1 transfer case; none of which the Sahara will have.
  5. Nov 25, 2018 at 9:32 AM
    I don't think the "Rubicon" option was available before 2003
  6. Nov 25, 2018 at 3:41 PM
    aluminations
    Dan
    98 Sahara
    Thanks for the replies. It appears that the previous owner liked Rubicon on the hood. Only true Jeepers would know the diff.
    JKBob 25, TJ_abuser and chris4x4 like this.
  7. Dec 26, 2018 at 12:27 AM
    steelhd
    steelhd Member
    2004 LJ
    My non-Rubicon LJ had Rubi stickers on the hood when I bought it. They were gone within an hour of me getting it home. :)
  8. Dec 26, 2018 at 2:09 AM
    Nope it was first available in 2004
