Screaming
Discussion in 'Wrangler TJ (1996-2006)' started by LucerneWolfe92, Mar 14, 2019.
  1. Mar 14, 2019 at 6:19 AM
    LucerneWolfe92
    LucerneWolfe92 [OP] New Member
    Andrew
    1997 Jeep Wrangler
    My 1997 Jeep Wrangler just sat for a year. When I got to turning it on and it began screaming. Bearing going out, it sounded. So I pulled the obvious; a seized alternator pulley and replaced it. Still screaming. I pulled my AC compressor pulley and put in a bypass but it's still screaming. Except now I have a Check Gauges light and it appears it's not getting to temp.. I stopped it yesterday along the road to see if I wanted to continue and it refused to start back up. The screaming is light at first but gets louder as I lead into the gas. Any help, please? I've tried YouTube remedies on the 4.0 but nothing is working..
  2. Mar 14, 2019 at 6:34 AM
    removing the year in county lead in might be a good start.
    What type of jeep? year, model etc...
    Of course check engine oil - gotta ask.
    The not getting temp - check coolant,
    When check gauge warning come on did you see - coolant temp or oil pressure gauge reading?
    Remove serpentine belt this will remove all accessories from troubleshoot.
    when key is moved to start -
    1) engine cranks wont start?
    2) just clicks are heard - no crank?
    3) water pump pulley will spin?
  3. Mar 14, 2019 at 7:07 AM
    Did you replace the serpentine belt?
    After sitting it has likely weathered and you may be hearing the belt slipping.
    As Awrech said/asked, did you notice any gauge not reading correctly when the check gauges light came on?
  4. Mar 14, 2019 at 7:19 AM
    LucerneWolfe92
    Andrew
    1997 Jeep Wrangler
    I'm not sure if it wasn't reading correctly, or not at all. My coolant temp wasn't going up so I figured I'd sit it back at the house until something was figured out. I'm thinking it's something as simple as a new belt; I'd noticed the underside of it where the ridges are has been stripped? Sort of. With a lack of better words.
  5. Mar 14, 2019 at 11:34 AM
    Welcome @LucerneWolfe92 ...seems you got several good leads to resolve your issues which involves a few separate systems. Removing the serpentine belt could help isolate the squealing as a/c clutch or bearings can squeal loudly. Make sure the battery is fully charged to remove one variable for the no-start. Any check engine lights get the codes read. ETC
  6. Mar 14, 2019 at 12:35 PM
    Could be dried out bearing on the water pump especially if the seal was leaking slightly when it was parked.
  7. Mar 14, 2019 at 1:21 PM
    On another vehicle there is a whining noise from probably the water pump bearings but no drip :fingerscrossed: at this time but ymmv
  8. Mar 14, 2019 at 1:48 PM
    There fixed it for ya.
    aggrex[QUOTED] likes this.
  9. Mar 20, 2019 at 10:20 AM
    Speaking of screaming my 52 inch light bar whistles terribad on the highway. Has anyone engineered a fix for this?
  10. Mar 20, 2019 at 10:28 AM
    Someone markets a product that attaches to the back of the the lightbar to deflect or change how the airflows through the lightbar. Check the reviews on Amazon for more info.
  11. Mar 20, 2019 at 2:53 PM
    TJ_abuser[QUOTED] likes this.
  12. Mar 20, 2019 at 2:56 PM
    That's cool but damn 140 bucks suddenly I cant hear that whistle....
  13. Mar 20, 2019 at 2:57 PM
    Has anyone done their own SYE kit on the 231? And if ya have do you want to come hold my hand while I do mine lol..... I got beer and other refreshments lol
  14. Mar 20, 2019 at 3:05 PM
    That's on my list of things to do as well, after I get around to adding another inch or two to the rear suspension.
