Single White 2012 Jeep Looking for a Rough and Wild Ride
Discussion in 'Wrangler JK Marketplace (2007-2017)' started by Offroadingjunky, Dec 28, 2020.
  1. Dec 28, 2020 at 10:39 AM
    Offroadingjunky
    Offroadingjunky [OP] New Member
    Additions to your new Jeep include: Poison Spider body armor, Metal Cloak - Game Changer full suspension upgrade, 4” suspension (not body) lift with fully adjustable Fox reservoir shocks, mechanical sway bar disconnectors, front CV axle joints, front/rear e-lockers, upgraded air filter intake and exhaust to maximize power and torque from the V6 engine, WARN winch with remote control, synthetic cable, Steel-reinforced braided brake lines, a wench with an extra light synthetic towline for safety, one of the biggest Stabilizer shocks on the market, a compact and programmed CB Radio with a removable antenna, and BedTred lining. With all this, not only is your Jeep ready to take your off-roading experience to the next level, but it’s also prepared to get dirty with you too. Additional Details: Jones Jeep did all of the upgrades on this vehicle & it was maintained by Jeep Masters The Jeep’s interior is coated with BedTred making it rinse friendly, and mold resistant for easy clean up after a good off-roading trip. This sound-absorbing material also means you’re not bombarded with roadway noise. The steel lockbox ensures that your valuables stay protected while you are on your adventure. This lockbox is secure, even with the top off, and is sealed for water resistance. I have stored laptops in this lockbox during a rainstorm and have had no issues. High Lift Jack included and well as several Jeep specialty tools. (Jeep Kit, manual, & programmer {helps with airing down tires in less than a minute, programs for fuel efficiency, etc}) Bestop Glass hatch has a build-in defrosting system and a box wiper that can be attached. Poison Spider body armor additions as well as Spider shades for the roof/sides/doors and rear. Mastercraft seat covers are harness ready for those rough rides and are waterproof as well. Trek Amor cover over the backseat is also waterproof - there are additional hardcore covers specifically for off-roading that protect the seat if you get caught out in the elements. Sway bar connectors with a pull pin disconnect for off-roading like a pro. Adjustable reservoir Fox shocks on all four wheels. Steel enforced, braided brake lines. Stock engine, but with the Air Raid filter, intake, and exhaust upgrades, it certainly doesn’t sound like one SPod is independently protected so that if one system fails, the rest go on unaffected. The SPod also has a compatible app to easily control the on/off functions. The Sound System is marine-grade - speakers and all with a head unit that is ready for the addition of a subwoofer. 6 speakers with all new wiring to the head unit. Bluetooth compatible. Removable CB Radio antenna. The compact CB radio inside is programmed and ready for use. Metal Cloaking LED Lights Sliding windows on hybrid top E Lockers/Differential lockers on front and rear Front Wench Extra light synthetic towline for safety Pro Link Tow straps included One set of full doors and one set of half doors with Spider shades Stabilizer shock - biggest one on market Sway bar connectors with a pull pin disconnect for off-roading like a pro Adjustable reservoir Fox shocks on all four wheels Steel enforced, braided brake lines Upgraded Aluminium latches Heated seats
    Price Decrease~ $48,000
    Do you enjoy off-roading? This 2012 Jeep JK is not your typical ride. With upgrades focused on reliability, functionality, and fun, this vehicle will enhance your off-roading experiences.
    Can you handle off-roading with the hybrid top? This multifunctioning top has sliding back windows and a Bestop hatchback that can be removed to let your hair (or lack thereof) blow in the wind.
    Worried about the hot Texas sun beaming down on you during your adventure? No worries here - with Spider shades for the roof, sides, and back of the Jeep, you’ll be chillin’ in the shade. While you are enjoying the shade on your adventure, turn your experience up a notch by taking advantage of your Marine-grade sound system with 6 speakers. Not enough sound for you? The wiring is ready for a subwoofer addition.
    Additions to your new Jeep include: Poison Spider body armor, Metal Cloak - Game Changer full suspension upgrade, 4” suspension (not body) lift with fully adjustable Fox reservoir shocks, mechanical sway bar disconnectors, front CV axle joints, front/rear e-lockers, upgraded air filter intake and exhaust to maximize power and torque from the V6 engine, WARN winch with remote control.
    If you are looking for a way to ramp up the adventure in your life, this is the vehicle for you. Take your travels to the next level and find the freedom in off-roading with this gem of a Jeep!
    See below for additional specs and details about your new Jeep.
    Cash or Money order preferred.
    Austin, TX 78704
    Serious inquiries only.
    Additional Details:
    Jones Jeep did all of the upgrades on this vehicle & it was maintained by Jeep Masters (Austin, Texas)
    • Removable CB Radio antenna. The compact CB radio inside is programmed and ready for use.
    • Metal Cloaking
    • LED Lights
    • Sliding windows on hybrid top
    • E Lockers/Differential lockers on front and rear
    • Front Wench
    • Extra light synthetic towline for safety
    • Pro Link Tow straps included
    • One set of full doors and one set of half doors with Spider shades
    • Stabilizer shock - biggest one on market
    • Sway bar connectors with a pull pin disconnect for off-roading like a pro
    • Adjustable reservoir Fox shocks on all four wheels
    • Steel enforced, braided brake lines
    • Upgraded Aluminium latches
    • Heated seats
    Links to noted purchases:
    USA Alloy-Rear Axle Shaft Chromoly D44 NON-Rubicon 12156
    D44 Eaton E-Locker 30 Spline 19969010
    MasterCraft Seat: Baja RS DirtSport Edition Black/Black
    Poison Spyder JK Crusher Flares Standard width Steel
    MetalCloak - 3/5 JK Duroflex Suspension Kit
    Fox Racing - 2.0 Performance Series Reservoir shocks
    Eaton E-locker D30 with 30spline
    RCV 30 spline axle shafts CVJ30-JK
    PS-JK Brawler light Bar Mount for Front Bumper
    PS-Brawler Rocker JK 2dr (Raw Steel)
    KC-JK 7" LED Headlight Kit
    SPOD - SPOD - 20122 JK LED SPOD and Source System
    Dynomax 12-15 "RockCrawler" Cat-Back System (39524)
  2. Jan 1, 2021 at 9:39 AM
    Due to the overnight New Years celebrations with bloodshot crossed eyes you almost got me at
    “Single White ————-Looking for a Rough and Wild Ride”
    :anonymous:
