Slight smell of antifreeze when AC NOT on full cold
Discussion in 'Wrangler TJ (1996-2006)' started by hutchtoy, Sep 24, 2017.
Getting a slight smell of antifreeze when AC not on full, bad heater core coming? No leaks.
  1. no
    0 vote(s)
    0.0%
  2. yes
    0 vote(s)
    0.0%
  1. Sep 24, 2017 at 7:07 PM
    hutchtoy
    hutchtoy [OP] New Member
    04 unlimited
    raised body and suspension, larger tires
    Been hot in the Midwest this past week and when I run the AC but NOT at full cold I get a slight smell of antifreeze. At full cold I don't. No leaks anywhere. Am I just catching a bad heater core early? Not looking forward at taking out the whole dash to fix it and not a fan of stop leak stuff.
  2. Sep 25, 2017 at 7:40 PM
    I had this happen in a Chevy beleive it or not.
    First I'm going to say. Do not under any circumstances use any type of stop leak. It may cure your issue for the time being. But..you will end up having issues bigger than you expected down the line.
    Heater core?? Could be. Honestly. The only issue I've had with heater core. Yeah...it did blow. But I only had a smell of anti freeze just before it blew. Also had the same issue when a freeze out plug blew. Again..on a Chevy.
    Just my experiences with similar issues. Hopeing to spark a members fix to maybe help here.
    OFFGRID likes this.
