Sometime it starts, sometimes it won't...had the safety neutral replaced
Discussion in 'Wrangler JK (2007-2017)' started by jeep2007, Jul 10, 2019.
  1. Jul 10, 2019 at 5:07 AM
    jeep2007
    jeep2007 [OP] New Member
    al
    2007 wangler x 2 dr
    offroad front bumper led headlights roof led light bar
    i can not figure out why this is happen iput new start in it replace safety neutral i got this jeep used off a car dealer and i had it two years nowand had to put a new motor in it because spun a bearing.now i have this problem trying to solve.not happy with jeepat all i had cj and yj no problem with themanyone have this problem and if so can you help me thanks
  2. Jul 10, 2019 at 6:19 AM
    This is a 2007, with a 42RLE.
    A start circuit was SO simple but MICAHI has replaced KISS. GD millennials, they could ruin a "good" dream.
    RANT OVER
    you claim "replace safety neutral' is this the TRS Transmission range sensor?
    Start with a SCAN using a good scanner as there may be some codes that may help (ie P0706).
    The wiring is STOCK no added BS - remote, added alarm, etc.
    Might want to swap relay with a like and less used relay - horn,?
    There is a known issue with TIPM time permitting I will get details while I await the answers to above. Scan and modifications, and relay swap/check.
  3. Jul 22, 2019 at 8:02 AM
    jeep2007
    al
    2007 wangler x 2 dr
    it has a after mkg remote starter and power door locks
  4. Jul 22, 2019 at 8:20 AM
    That aftermarket BS would be a focus. BUT you still need to scan.
    Are you comfortable with wiring diagrams a scanner and a DVOM ?
    We could get you a wiring diagram of start circuit to aid troubleshooting.
