Spacers and Lifts
Discussion in 'Wheels & Tires' started by Butch Shingleton, May 19, 2021.
  1. May 19, 2021 at 9:53 AM
    Butch Shingleton
    Butch Shingleton [OP] New Member
    2016 Jeep Wrangler Unlimited
    I am trying to put 315/70R17's on my stock Jeep Wrangler Unlimited using stock rims. Do I need to use spacers and if so, how thick? I am also going to use a 2.5 inch lift if that will be enough. Thoughts?
  2. May 19, 2021 at 10:16 AM
    If you’re going to use the OEM wheels you will likely need wheel spacers because of the 6.25” back spacing. Use high quality hub-centric wheel spacers from a known brand for best results. My JK runs 1.5” Spider Trax and they move the tires just outside of the fender.
