Speedometer erratic
Discussion in 'Wrangler YJ (1986-1995)' started by czukmilyr13, Nov 18, 2019.
  1. Nov 18, 2019 at 6:45 AM
    czukmilyr13
    czukmilyr13 [OP] New Member
    ‘92 Wrangler
    I have a ‘92 Wrangler 5 speed and the speedo is completely erratic. It usually doesn’t work until I get into 2nd or 3rd gear other times it’ll sit around 10mph. Other times it’ll be correct then it’ll jump up to 65-80mph when I’m clearly not going anywhere near that fast. The tcase was leaking on the sensor but I resealed it and cleaned all the components and it’s still acting crazy. Any ideas on what to check or change would be appreciated.
  2. Nov 18, 2019 at 7:34 AM
    Is it a cable driven or electric?
  3. Nov 18, 2019 at 2:11 PM
    Replace the speedo cable and use the speedo cable lubricant.
