Speedometer Gear??
Discussion in 'Wrangler TJ (1996-2006)' started by kyletraci, Dec 7, 2017.
  1. Dec 7, 2017 at 7:58 AM
    kyletraci
    kyletraci [OP] New Member
    Kyle
    2001 Wrangler Sport
    On my 2001 Jeep Wrangler, the speedometer is off. I looked up the tire size and matched it up with the stock rear gears and came up with a 30 tire and 307 rear gear. I ordered a 27 tooth speedo gear and according to my GPS I am doing roughly 8 miles an hour faster than the speedometer indicates. Do I go with a larger or smaller gear for the speedometer. Thanks!
  2. Dec 7, 2017 at 10:22 AM
    I order a programmer to correct it electronically in the computer. As for you question, I believe if you are reading too fast you need to slow it down so more teeth/larger equals fewer rotations and slower speed. Anybody else confirm this?
  3. Dec 8, 2017 at 7:00 PM
    If your Speedo gear doesn't fix the issue. I'd pick up a programmer as @OFFGRID suggested. A Superchip is fairly cheap and would do the trick.
  4. Dec 9, 2017 at 7:44 PM
    kyletraci
    Kyle
    2001 Wrangler Sport
    I will look at a getting a programmer. I work on a military base and they are crazy about speeders. Thanks for the help!
  5. Dec 9, 2017 at 9:03 PM
    Well this is what I did I called Quadratec and told my rear end gears and they in return told me what speedo gear I needed and with my GPS I’m right on. FYI there # is 800-745-5337 hope this helps.
