Steering stabilizer
Discussion in 'Cherokee' started by Jticketgene, May 15, 2018.
  1. May 15, 2018 at 8:06 AM
    Jticketgene
    Jticketgene [OP] Member
    Gene
    98 xj
    I’m putting on all new skyjacker shocks on my 98 xj. Should I replace the steering stabilizer also ???
  2. May 15, 2018 at 9:14 AM
    boondoc89 Well-Known Member
    I would only because you're buying all new shocks anyways. Might as well spend a little extra cash and update that one too. Its entirely up to you tho.
  3. May 15, 2018 at 9:44 AM
    Welcome! I concur with boondoc89's suggestion or the steering stabilizer can be upgraded later. If it ain't leaking or making noises it may have some life left. Make the decision based off the age of the unit, how it's steering or your pocket.
    Jticketgene[OP] likes this.
  4. May 15, 2018 at 9:45 AM
    I opened this thread expecting to see a, "I've got death wobble because my steering stabilizer is bad"....
    But sure if you are going bigger tires and already buying new shocks you could get a new steering stabilizer to help control the bump steer of the larger tires.
  5. May 15, 2018 at 10:22 AM
    Welcome aboard!!
  6. May 15, 2018 at 11:12 AM
    Jticketgene
    Gene
    98 xj
    Thanks man
