Stock carb off road
Discussion in 'CJ' started by pastor scott, Oct 7, 2018.
  1. Oct 7, 2018 at 11:32 AM
    pastor scott
    scott
    1978 CJ 7
    none right now
    On my 78 304 it has th stock carb. How is this in off camber situations .
    Any Fuel loss to issues like flooding
    If it is an issue what's a good replacement .
    Thanks ALL
    Ps Scott
  2. Oct 7, 2018 at 2:54 PM
    My experience is significant loss of power on steep climbs, and If you stall on a steep climb or decent it is very hard to get it started because the floats in the bowl will not be level allowing the bowl to empty and therefore starving the carb of fuel. Invest in a good hand throttle cable like from Teraflex about$40, and have a good battery like the Odyssey Red top or Optima yellow top, or Northstar Marine battery so as to not drain your battery when trying to start in offcamber situations. Look into Howell TBI injection or Fitech TBI system for consistent fuel flow at all elevations and angles.
  3. Oct 7, 2018 at 6:39 PM
    pastor scott
    scott
    1978 CJ 7
    none right now
    Thanks .That's the answer and advice I was looking for .
