Strange Vibration
Discussion in 'General Jeep Discussion' started by law41159, Mar 6, 2018.
  1. Mar 6, 2018 at 6:31 AM
    law41159
    law41159 [OP] Member
    2015 black wrangler sport unlimited
    none
    I was wondering if anyone knew why i get a vibration when i am in low RPM's around 1 ? I't is driving me crazy,as soon as i step on the gas it comes out,but as soon as its in around the "1"rpm area it starts again,but nothing above or below? could this be transmission,its a 2015 JKU 20,000 miles automatic.
  2. Mar 6, 2018 at 9:44 AM
    Is this happening when its in Drive, or at idle in Neutral?
  3. Mar 6, 2018 at 11:40 AM
    My wife's van would do that when stopped with the vehicle in gear, but no check engine light.
    I changed the spark plugs and wires and it went away.
    Might be worth a shot to change the plugs (yours doesn't have plug wires as it is a coil on plug design). May be at least take a look at them. 20K seems low for a plug to be worn and/or for a coil to start failing.
    Is it still under the factory warranty by time?
