Sway bar light continuously blinking
Discussion in 'Wrangler JK (2007-2017)' started by Ransom20, Jun 12, 2020.
  1. Jun 12, 2020 at 10:38 AM
    Ransom20
    Ransom20 [OP] New Member
    2013 jku
    So I'm sure this issue is out there given the electronic sway bar connection. Or asbs. The light came on a few days ago and continues to blink. I've checked fuses and I sway bar are locked. I have not used the system in over a year. I did go through several deep water but nothing more than like 6-8 inches. Any thoughts?
  2. Jun 12, 2020 at 11:17 AM
    Welcome @Ransom20 ...might want to open&inspect the sway bar disconnect casing as it’s not exactly waterproof. You might discover that moisture has damaged the $$ electronics and gummed up the mechanism. If you’re lucky it may work after clean up. Otherwise there are other options.
  3. Jun 12, 2020 at 7:24 PM
    can you unplug it? or rewire it to turn the light off?
