Switch Panels
Discussion in 'Electrical' started by AdventureWagon, Oct 3, 2018.
  1. Oct 3, 2018 at 5:02 PM
    AdventureWagon
    AdventureWagon [OP] Member
    Upstate New York
    '08 JKU Sahara
    I am looking for some suggestions for some simple switch panels. I only need about 4 switches. What are you all using?
  2. Oct 3, 2018 at 7:30 PM
    I'm sure you will get a couple of suggestions such as a Spod.
    I however plan on building my own using cat5 cable to connect the switch box and relay box.
    Have had it planned out for a couple years but has been on the back burner, I even have everything I need.
    I like to build that kind of stuff though, it's not for everyone.
  3. Oct 3, 2018 at 8:04 PM
    I like my 6 switch S-Tech system which is also available in 4 switches. Made in the USA, EZ to install and you only need to go through the firewall once. Switch pod mounts below the footman loop rather than on it.
  4. Oct 4, 2018 at 10:31 AM
    I made my own, with the switches mounted in the A pillar.
  5. Oct 4, 2018 at 6:36 PM
    I have a Trigger Remote System. It's all installed in engine compartment. No fire wall entries. Basic remote push button controller.
