Taking Orders on Toyota, Tundra (2022-On) Kits
Discussion in 'Baja Designs' started by Baja Designs, Aug 22, 2022.
  1. Aug 22, 2022 at 2:37 PM
    Baja Designs
    Paul M.
    From fog lights to light bars, light up the night wherever your next adventures take you. Our scientists of lighting have crafted light solutions from mild to wild to make sure every Tundra enthusiast is able to torch the road ahead of them.
    From the stock Tundra to the TRD Pro, our LED Light Kits for the Toyota Tundra are designed to mount cleanly to your vehicle. The all-new third-generation Toyota Tundra represents a bold new approach in both styling and performance. Make your Tundra stand out from the rest with high-power lighting kits from Baja Designs. Do not let the night hold you back on your next adventure and get your Tundra Kits today!
    GsQH2UUbyaAvrv_ix9yvXP1Jl3tTugUZspZjvJrJ_5f9b24c4438750663a98c6f3b51caf665d9f4283.jpg
    See Post Below for more kit info
  2. Aug 22, 2022 at 2:42 PM
    Baja Designs
    Paul M.
    2022 Toyota Tundra S2 Sport OEM Fog Light Replacement Kit | SKU:448080 | Link: Toyota S2 Sport OEM Fog Light Replacement Kit - Toyota 2022 Tundra - Baja Designs - Off-Road LED & Laser Lights | Automotive, Jeep, Truck, UTV, ADV, Dirtbike
    The S2 Sport Fog Light Replacement Kits give you the ability to replace your factory lighting making for quick and easy installation with no difficult wiring, trimming, or splicing.
    8-eMUZAiYCbeqtT--PKMsmJiP7uhWcPAjqbploTL_ac58f9545a1d2837312d5c2f7de81e0db7c8737d.jpg Ps2wx7_-NICe_iriFJp8V75JF06pAyJOJYoc0RBE_9f8936a4a41c0d7447ce48c2647f6ed5f793f946.jpg
    S2 Sport setup includes the following:
    • (4) S2 Sport, Wide Cornering
    • (2) Mounting Brackets
    • (2) Adapter Harness
    • All necessary hardware
    Specifications (Per Light):
    • Lumens: 1,130
    • Wattage/Amps: 12W / 0.9A
    2022 Toyota Tundra, 20” S8 Behind Bumper Kits| SKU: 448076 | Link: Toyota S8 20 Inch Behind the Bumper Light Kit - Toyota 2022 Tundra - Baja Designs - Off-Road LED & Laser Lights | Automotive, Jeep, Truck, UTV, ADV, Dirtbike
    The new Toyota Tundra 20” S8 Behind Bumper Kit gives you off-road performance while maintaining a seamless appearance. This kit utilizes our 20” S8 light bar with no major modifications to the vehicle.
    kRp840Ny1J_R-bd5zFFlfeV02qWhWU596I_R9tt1_64e6e5c88028c082e6b559e48ada4ef38d9825e5.jpgIoONebhK8x8F9n9oAZsLQTdIecs6etbzzDp6aU_W_3a8c30b3bebb8396bed01f19d6bf5d584b0323c2.jpg
    20” S8 Clear Setup includes the following:
    • (1) 20” S8 Clear Driving/Combo Light Bar
    • (1) Wiring Harness
    • (1) S8, Backlit Add-On
    • Lumens: 12,700
    • Wattage/Amps: 120W / 8.0A
    2022 Toyota Tundra TRD PRO OEM, 20” S8 OEM Replacement Kits | SKU: 448078 | Link: Toyota S8 20 Inch TRD Pro OEM Grille Light Kit - Toyota 2022 Tundra - Baja Designs - Off-Road LED & Laser Lights | Automotive, Jeep, Truck, UTV, ADV, Dirtbike
    The 20” S8 OEM Replacement Kit gives you the ability to replace the preexisting light that comes with your 2022 Toyota Tundra TRD Grille. This kit allows you to maintain the low profile appearance while maximizing the performance with our 20” S8 light bar.
    TwsVgS4I_cXI0d7OYbFNCvecIzgZsLj91IleLdST_97cf4b106658e446f7f093f83defd87a3fc5c824.jpg
    • Lumens: 12,700
    2022 Toyota Tundra, A-Pillar Kits | SKU: 448072 | Link: Toyota XL Sport A-Pillar Kit - Toyota 2022 Tundra - Baja Designs - Off-Road LED & Laser Lights | Automotive, Jeep, Truck, UTV, ADV, Dirtbike
    Baja Designs Toyota Tundra A-Pillar Kits give you the ability to continue your adventures late into the night! These kits give you the option to utilize our XL Sport, XL Pro, or XL80. With the provided A-Pillar brackets, installation is simple and Baja Designs brackets are designed so there is no vibration, even when running down wash-board roads.
    Z7S-Z5SWFUZtskV2KmzVT1QSslMXfSUNOxklTo2e_008b569f546eaca477bf63d1102060a72cd97fb2.jpg
    XL Sport setup includes the following:
    • (2) XL Sport, Driving/Combo
    • (2) A-Pillar Mounting Brackets
    • (2) XL Clear Spot Lens
    • (2) XL Clear Wide Cornering Lens
    • Lumens: 3,150
    • Wattage/Amps: 26W / 2.0A
    XL Pro setup includes the following:
    • (2) XL Pro, Driving/Combo
    • Lumens: 4,600
    • Wattage/Amps: 40W / 2.9A
    XL80 setup includes the following:
    • (2) XL80, Driving/Combo
    • Lumens: 9,500
    • Wattage/Amps: 80W / 5.5A
    2022 Toyota Tundra, A-Pillar Kits LP4 | SKU: 448075 | Link:Toyota LP4 A-Pillar Kit - Toyota 2022 Tundra - Baja Designs - Off-Road LED & Laser Lights | Automotive, Jeep, Truck, UTV, ADV, Dirtbike
    Baja Designs Toyota Tundra A-Pillar Kits give you the ability to continue your adventures late into the night! These kits give you the option to utilize our LP4. With the provided A-Pillar brackets, installation is simple and Baja Designs brackets are designed so there is no vibration, even when running down wash-board roads.
    p-ByO8vbx441Erj-5-vSpep1G1A1e-EY7j2OcBcI_f1e88a4b88a20bbb6f7b89f1218e2e512144eac8.jpg
    LP4 setup includes the following:
    • (2) LP4, Driving/Combo
    • (2) Clear Spot Lens
    • (1) IPT Reflector Cover Kit
    • Lumens: 7,050
    • Wattage/Amps: 60W / 6.5A
    • IPT Lumens: 1,700
    • Wattage/Amps: 15W / 1.0A
    • Backlight Wattage/Amps: 4.8W / 0.35A
    2022 Toyota Tundra, S2 Sport Reverse Kit| SKU: 448082 | Link:
    Looking to get dust lights or reverse lights for your 2022 Toyota Tundra? Baja Designs has you covered with our reverse light kit. This kit comes with lights, brackets and wiring harness making it a breeze to get rear-facing light setup on your truck!
    MVsG7vfPEVD_d8IJYlTnzLne4qQBbUZa0Xu-54eU_de121c0aa71f707f93354211f24a5a4e01c4cafd.jpg
    • (2) S2 Sport, Wide Cornering
    • (1) On/Off Wiring Harness
    • (1) 10’ Extension Harness
    • (1) 55” Wiring Splitter
    • Lumens: 1,130
  3. Aug 22, 2022 at 4:19 PM
    Might be the wrong forum….just saying
  4. Aug 22, 2022 at 6:31 PM
