Towing question
Discussion in 'General Jeep Discussion' started by AGeezerAndHisJeep, Aug 13, 2022.
  1. Aug 13, 2022 at 10:47 AM
    AGeezerAndHisJeep
    AGeezerAndHisJeep [OP] Member
    Michael
    2022 2 door Sport S
    tow base plate, side rails
    I have no current plans to tow a trailer with my 2 door JL but I wondered about the towing capacity. I thought it would be simple - 4 cylinder would have a lower towing capacity than a 6 cylinder - but that is not how it apparently works. See the screenshot from the manual.
    The 2 door, both 4 and 6 cylinder, have a 2000 pound towing capacity and the 4 door, both 4 and 6 cylinder, have a 3500 pound towing capacity. Can someone explain to me why that is? Is it due to the frame? or different gearing in the transmission? Or the higher weight of the 4 door? I just don't see what it might be.
    Thanks.
  2. Aug 13, 2022 at 6:01 PM
    Biggest limitation is the shorter wheelbase. Towing at the limits or slightly over may feel okay initially but there is very little reserve capacity for handling/braking/swerving. Instead of typical frame mounted hitches check out the JK/JL hitch mount on the rear crossmember it does look a bit sketchy. IMO stick with the lower limits and drive conservatively while towing in a JK/JL
  3. Aug 14, 2022 at 8:45 AM
    AGeezerAndHisJeep
    Michael
    2022 2 door Sport S
    Probably the best advice.
    We used to tow a small trailer behind our Jeep Libertys, but they were rated for 3500 pounds and the trailer was well under that. I guess with the 2 door JL I will just not tow anything other than a small utility trailer, if that.
