Trans swap manual to auto
Discussion in 'CJ' started by Drd88, Aug 31, 2018.
  1. Aug 31, 2018 at 3:27 PM
    Drd88
    Drd88 [OP] Active Member
    Dan
    Silver creek new york
    79 cj 5/2000 wrangler
    360amc Borg Warner t-18 trans
    Sooo...let's just say I am thinking about possibly swapping..my t18 manual to automatic.....how much pain am I in for... suggestions..ideas? Thanks all . Danny
  2. Aug 31, 2018 at 8:27 PM
    MT>AT achievable with some significant work. Cost effective? Problem with the MT? Far from a mechanic but these things come to mind that might be needed trans cooler, radiator with trans lines, shifter, console, flywheel, trans adapter, crossmember, trans mount, drive shaft, wiring harness, etc.
  3. Sep 1, 2018 at 12:38 PM
    Drd88
    Dan
    No problem with MT...my ageing body and ankles can't take shifting is all..
  4. Sep 1, 2018 at 7:12 PM
    Not my first choice but replacing your MT with an AT model that meets your expectations might be easier than the work involved to make the conversion.
  5. Sep 2, 2018 at 7:02 AM
    agree with above - find a jeep with an automatic.
    Drd88[OP] likes this.
  6. Sep 2, 2018 at 11:44 AM
    Drd88
    Dan
    Yeah probably just going to fix the poor job previous owners did to this one to make it safer for next owner.... thanks dudes
  7. Sep 7, 2018 at 6:10 AM
    Is this for the CJ5? Im not sure if it will even fit, unless you have moved your read axle back. On my CJ7 I went from a T150 3spd to a TH350 adapting it to the 258 motor and Dana 20 TCase. After moving my rear axle backwords and clocking it up because I had to install a double cardan drive shaft because I only had an 18in shaft which caused my drive angle to be too high for the standard shaft. The cost was more than it was worth IMO. If you truly have a T18, that is the best best MT for crawling. I looked for a CJ T18 for years, before I gave up and went with the TH350.
    Drd88[OP] and Prerunner1982 like this.
