Transfer case swap
Discussion in 'Cherokee' started by Gwh1953, Jul 23, 2019.
  1. Jul 23, 2019 at 4:39 PM
    Gwh1953
    Gwh1953 [OP] Member
    George
    99 grand Cherokee
    Can a Nv 242 transfer case swap out with a nv247 transfer case .
  2. Jul 23, 2019 at 6:14 PM
    Sorry. I don't have the knowledge to help.. But @OFFGRID does. You out there Peter?? I'm sure I'll learn something here. :popcorn:
  3. Jul 25, 2019 at 12:45 PM
    Gwh1953
    Gwh1953 [OP] Member
    George
    99 grand Cherokee
    I recently purchased a 1999 grand Cherokee all wheel drive. It has 285/75 r 16 on and rear and 265/75 r 16 on front. I know that tire size must be equal on all 4 wheels. I amwondering what damage was caused to the transfer case and differentials.The front drive shaft turns freely when engaged in all wheel drive between the transfer case and the front differential and in 4 low it goes to low range but the front shaft does not engage the front axle differential. I an going to put the proper size tires on it and change the transfer case fluid. If that does not solve the problem. What is the next step? I am possibly considering swap to NP(nv) 242 system. What would you recommended to solve the problem.
