Transmission issues
Discussion in 'Wrangler TJ (1996-2006)' started by Damien2323, Sep 23, 2018.
  1. Sep 23, 2018 at 8:16 PM
    Damien2323
    Damien2323 [OP] New Member
    Damien
    1997 Jeep Wrangler
    installed new trans (used) and a brand new clutch went for a ride shift into fifth gear and car just revs up when I press gas no power to wheels what’s could this be no grinding of gears just flat out no power to tires. Please help sitting in garage just waiting for some help lol any ideas need some help
  2. Sep 23, 2018 at 10:23 PM
    Welcome! Sounds like the transmission you swapped in could be faulty? Maybe the linkage, or synchronizer?
  3. Sep 24, 2018 at 8:07 AM
    Welcome! As mentioned the used transmission is probably the issue. Problem engaging 5th gear at higher speeds when 1 thru 4 were not problematic should be indicative of the trans and not necessarily your installation.
