Transmission over temp...
Discussion in 'Cherokee' started by Jeep05hemi, Jul 25, 2018.
  1. Jul 25, 2018 at 12:27 PM
    Jeep05hemi
    Jeep05hemi [OP] Member
    Samantha
    05 Jeep Grand Cherokee
    I recently had my transmission serviced and now it keeps telling me it's over temp. I hada re flash a few years backas well. Seems like something isn't cooling off my transmission.... help plz i don't know what to do to start to fix it
  2. Jul 25, 2018 at 2:41 PM
    post ALL the codes that are appearing.
    there was NO issue before service?
    What was done with trans service?
    Were the 2 filters changed?
    Was correct fluid used?
  3. Jul 25, 2018 at 4:40 PM
    Welcome tot he site!
  4. Jul 25, 2018 at 4:42 PM
    Jeep05hemi
    Samantha
    Hasn't thrown any codes that i know of other than my dash saying transmission over temp. I had a re flash done and my husband thought it was tacking higher than it should so we got it serviced. Had no issues with transmission over heating or over temp then after the first service it said transmission over heating so we took it back and had it done again both filters were checke changed and they better have put the right fluid in it. There a 5☆ dealership.
  5. Jul 25, 2018 at 6:17 PM
    Welcome! Have whomever serviced the trans check the trans temps while trying to replicate the problem your experiencing and confirm trans lines running through the radiator and/or auxiliary trans cooler for proper function. Take a pic of the "transmission over temp" warning for them.
  6. Jul 25, 2018 at 6:37 PM
    Jeep05hemi
    Samantha
    Ok thank you
  7. Jul 26, 2018 at 7:32 AM
    "my husband thought it was tacking higher than it should"
    My guess is that you did NOT use a jeep dealer for "service' and you did NOT check codes before spending? Am I right or Close?
    going foward -
    For sure follow up with the facility that did service- If you did NOT use a jeep dealer -
    Was the system flushed or was the pan dropped and filters changed. was the correct fluid used NOT universal or 1 type fits all ?
    Also have the system SCANNED for codes - a SCANNER needs to be used.
    TSB ....26-003-07 Flushing not recommended.
  8. Jul 26, 2018 at 8:36 AM
    Jeep05hemi
    Samantha
    It was a dodge jeep Chrysler dealership it can't flushed just changed and pan was replaced because itwas rusted.
  9. Jul 26, 2018 at 9:02 AM
    very good - a chrysler jeep dealer eliminates some of the questions...
    I still suggest SCANNING for codes* That service is often FREE an many auto part stores-
    That would give us more info to make a decision - where as dealer charges. this will help with info to address issue with dealer- was fine till you (dealer) worked on it
    *FYI not all codes will turn on the CEL and many will not show up on key on off trick.
  10. Jul 26, 2018 at 11:03 AM
    Jeep05hemi
    Samantha
    On thank you so much
