Transmission temps 850re
Discussion in 'Wrangler JL (2018+)' started by toyko joe, May 9, 2023.
  1. May 9, 2023 at 8:37 PM
    toyko joe
    toyko joe [OP] Member
    850re on the display we have a transmission temperature gauge. What should be my normal range on temperatures for city driving or highway or towing?
    I know above 220 transmissions really start to degrade their fluid but what should I consider normal and ok when I have minimal or no excess in weight?
    I ask because:
    There’s a delay between 3/4th when cold on first drive.
    After driving today under what I consider normal operating ie. city driving where I have 4 miles At highway speed the transmission temp as at 185*. This seems really high for a 8 mile trip without an excessive load.
    Your thoughts?
  2. May 10, 2023 at 6:06 AM
    Good to have an ATF gauge to monitor for excessive temps >220. I’d perform a drain & fill with OEM spec ATF fluid and consider adding a transmission cooler.
  3. May 10, 2023 at 8:00 AM
    Dirty Dog
    Dirty Dog Well-Known Member
    Mark
    2011 & 2013 JKU Rubicon
    It's fine at 185. Temps rise quickly and then stabilize. I'd add a transmission cooler if you plan on doing any towing or participating in any off highway hijinks.
