Trouble starting 2000 Wrangler
Discussion in 'Wrangler TJ (1996-2006)' started by Drd88, Dec 5, 2019.
  1. Dec 5, 2019 at 10:49 AM
    Drd88
    Drd88 [OP] Active Member
    Dan
    Silver creek new york
    79 cj 5/2000 wrangler
    360amc Borg Warner t-18 trans
    Helping a friend trying to get Jeep started...after she got gas Jeep wouldn't start...turned key nothing.. attendees helped bump start...got back to house...seemed like key wouldn't turn all the way...she changed out tumbler with out me present,said did same thing....I noticed a loose wire on starter... fixed...still nothing...bumped starter...Jeep turned over...humm not starter..took clutch position switch..jumped that nothing...had another mechanic friend check wiring....first no spark..when jumping from under hood fuse/relay panel..don't really want to chase wires for a week....any help will be appreciated....thanks dan
  2. Dec 5, 2019 at 11:00 AM
    Ensure there are good ground connections, i.e.:motor to frame. Might look at the solenoid too
  3. Dec 5, 2019 at 11:12 AM
    Drd88
    Dan
    Yeah went over all grounds... solenoid on starter seems to be ok..
  4. Dec 5, 2019 at 12:40 PM
    It could be the ignition switch which is separate from the ignition lock cylinder. It is located under the front part of the steering column (black box, top center of pic).
    Perhaps this thread will help as well, though it's for an XJ they are the same vintage and quite similar.
    https://www.jeeps.net/threads/starter-trouble.2617/
  5. Dec 5, 2019 at 2:24 PM
    Drd88
    Dan
    Yes thanks been trying to diagnose it before I start throwing parts at it... appreciate all the feed back
  6. Dec 6, 2019 at 6:33 PM
    Drd88
    Dan
    Jeep fixed thanks...piece of metal around actuator pin broke binding it upIMG_20191206_180456~2.jpg
