Trying to get pismo ready
Discussion in 'Wrangler YJ (1986-1995)' started by BlueLM, Apr 24, 2017.
  1. Apr 24, 2017 at 8:37 AM
    BlueLM
    BlueLM [OP] New Member
    1994 wrangler
    none-stock
    Hello, I am new to this type of forum. I have just purchased a stock 1994 Wrangler and want to use it at Pismo Beach (California). I need to keep height down to fit in trailer, but wondering what else I can do to my wrangler to get around the dunes with family?
  2. Apr 24, 2017 at 9:06 AM
    Rc Jeep
    Rc Jeep Well-Known Member
    Ryan
    '16 Rubicon
    Beedlock wheels so you can safely drop that tire pressure to under 10.
  3. Apr 24, 2017 at 9:08 AM
    Rc Jeep
    Ryan
    '16 Rubicon
    Just happen to be searching the Internet for random shit and came across omf wheels out of riverside ca. They do a stock rim beed lock conversion. Pretty interesting
  4. Apr 24, 2017 at 9:32 AM
    At lower speeds over the dunes I had no problems aired down to 20psi. Bring a shovel, piece of wood, jack, tire gauge and air pump.
  5. Apr 24, 2017 at 10:02 AM
    Welcome!
  6. Apr 24, 2017 at 5:25 PM
    How tall is your trailer. I bet you could do the Old Man Emu 2.5 in lift springs and run 33x12.50x15 tires on 15x8 wheels. For modest height lifts I really like the OME springs. They ride even better than factory. If you need or want another inch get 1 in lift shackles front and back. Get a winch and use a self setting boat anchor in the sand to winch yourself out then just drive over it to pull it out of the sand.
    Show us some pics. I like the squares myself.
  7. Apr 24, 2017 at 6:59 PM
    BlueLM
    1994 wrangler
    none-stock
    I have 76 inches of clearance in trailer, I like beed lock idea with a bit larger wheels than stock, I only have 4 inches to play in trailer as Jeep sits now. I plan on having jack and shovel. Will get solid piece of wood. I also air down to 18 PSI with those screw on auto deflators. I wonder if purchasing sand tires would be worth it? any stance on that?
  8. Apr 24, 2017 at 7:22 PM
    Rc Jeep
    Ryan
    '16 Rubicon
    If you're only going to 18 psi, you would be fine with a standard wheel. The beedlocks benefits kick in lower than 10.
  9. Apr 24, 2017 at 8:01 PM
    I run 10 psi without any problems on 37x14.50 You could run 12 psi on 33s. You could run the setup I mentioned earlier. You might have to let some air out of the tires. That's how I get mine in the garage.
    BlueLM[OP] likes this.
