Tune up didn't resolve hesitation issue
Discussion in 'Liberty' started by Dd14, Jul 4, 2018.
  1. Jul 4, 2018 at 5:56 AM
    Dd14
    Dd14 [OP] Member
    David
    04 Liberty has some hesitation when driving, rpms drop and a little hesitation. Mechanic said tune up would correct issue and mainly changed plugs. Issue still occurring should plug coils have been changed also?
  2. Jul 4, 2018 at 7:54 AM
    to me a technician suggesting a TUNE UP is a red flag.
    There is no longer any tuning to be done... The large diagnostic "sun" machines of yesterday are incorporated into your OBD system... OBD is also constantly monitoring and adjusting settings.
    A scanner should be used to observe the system,looking at codes and live data.
  3. Jul 4, 2018 at 8:27 AM
    Dd14
    Dd14 [OP] Member
    David
    No codes by scanner. Another thread mentioned the plug coils.
  4. Jul 4, 2018 at 9:34 AM
    Welcome! Anything in particular going on before this happens?
  5. Jul 4, 2018 at 9:59 AM
    Welcome! How long has this problem been occurring? Reviewed all the basic stuff yet?....like bad gas, clogged air filter, vacuum leaks, plug wires, etc? What's a tuneup?
  6. Jul 4, 2018 at 10:17 AM
    Dd14
    Dd14 [OP] Member
    David
    Hesitation usually happens about 30-40 mph, rpm drops you can feel it but when gas pedal pressed works through.Gas mileage has decreased dramatically in last month or so. Tune up? IK archaic term, all spark plugs only changed out.
  7. Jul 4, 2018 at 10:21 AM
    I would check the basics. Air filter, MAF/MAP clean, etc
  8. Jul 4, 2018 at 11:23 AM
    Did you use a scanner to check for codes - NOT key on off trick. DBL checking.
    With scanner what is ECT, Fuel Trims, o2 sensor voltages, Map,
    If no codes check and no data - check fuel pressure as there is no direct monitoring of fuel pressure...
  9. Jul 4, 2018 at 9:38 PM
    I had a 99 and 2002 dodge truck do this when I crossed 100,000 miles. I had to have the dealer flash my computer to correct it. At 200,000 it happened again on my 99 and I bought a programmer for it and that fixed it. I sold it before it reached 300,000 miles and my 2002 never saw 200,000.
  10. Jul 5, 2018 at 9:25 AM
    Dd14
    Dd14 [OP] Member
    David
    Now throwing code P0839. Would the sensor cause issues?
  11. Jul 5, 2018 at 10:13 AM
    confirm - 04 liberty 3.7L automatic4 wd showing p0839?
    List ALL codes.
    You used a SCANNER- ?
    a trnasfer case issue - P0839-4WD MODE SENSOR HIGH
    A scanner will make this easy, any other codes ? check freeze frame, look at sensor voltages...
    I suspect other codes.issues or lights
    POSSIBLE CAUSES
    TRANSFER CASE POSITION SENSOR INPUT CIRCUIT OPEN
    TRANSFER CASE POSITION SENSOR INPUT CIRCUIT SHORT TO VOLTAGE TRANSFER CASE POSITION SENSOR
    POWERTRAIN/ENGINE CONTROL MODULE
    INTERMITTENT OPERATION
  12. Jul 5, 2018 at 10:19 AM
    Dd14
    Dd14 [OP] Member
    David
    Key check. No other codes
  13. Jul 5, 2018 at 10:28 AM
    Ok lets get serious SCAN !
    Key trick will not show ALL codes All modules!
    The live data is needed to make this easy.
