Turn on Headlights 4.2 DIES!
Discussion in 'Wrangler YJ (1986-1995)' started by Morganacious, May 25, 2020.
  1. May 25, 2020 at 7:03 PM
    Morganacious
    Morganacious [OP] New Member
    1988 YJ
    Hi All, New here. Just bought a 1988 YJ. Runs great until I turn on the headlights. Any ideas?
  2. May 26, 2020 at 12:24 PM
    Turning on the headlights are probably causing a short circut that is not fuse protected. That would be a good place to start looking.
  3. Jun 9, 2020 at 1:21 PM
    Dooley the Clown
    Dooley the Clown Member
    1995 Firecracker Red YJ
    Tube bumper on rear with receiver hitch, 8000# Ramsey Winch, A-post mirrors
    Bad battery connection or weak battery. I had the same thing happen to me several years ago.
  4. Jun 9, 2020 at 4:20 PM
    Morganacious
    1988 YJ
    Thank you!! I will check that out.
  5. Jun 9, 2020 at 7:54 PM
    As mentioned check the positive battery cables for tightness or corrosion. Don't forget to inspect the GROUND wires too as there are more than one and they will deteriorate and fail causing issuesthumbnail.jpg .
