Turn signal/high beam purple wire has come loose
Discussion in 'Cherokee' started by jeep4mail, Nov 18, 2018.
  1. Nov 18, 2018 at 10:06 AM
    jeep4mail
    jeep4mail [OP] New Member
    Peggy
    1995 RHD Jeep Cherokee
    What is the purple wire with the white tracer. It has come loose from the connection
  2. Nov 18, 2018 at 4:14 PM
    Welcome to the site! Can you post a picture, or give more of a location?
  3. Nov 18, 2018 at 7:54 PM
    Welcome! As mentioned pics of the wire/connector may help us help you.
  4. Nov 19, 2018 at 5:28 AM
    Hello Peggy, welcome to Jeeps.net.
    What year is the vehicle?
    Regular Cherokee or Grand Cherokee?
  5. Nov 19, 2018 at 7:36 PM
    Welcome to the forum @jeep4mail .
    As posted above. More info would help.
  6. Nov 20, 2018 at 4:02 AM
    jeep4mail
    Peggy
    My current problem started with my headlights flashing from regular on to very dim. I replaced that switch. It did not fix the problem. I had to use my high beam to drive. Then that switch failed and my turn signal and 4 ways quit and I had to hold the switch on to have the high beam. Replaced that switch Sunday. Everything appeared to be working. Monday morning back to using high beam for light. Monday afternoon I had to hold the high beam switch on the entire drive home from work. Any ideas would be appreciated
  7. Nov 20, 2018 at 4:04 AM
    jeep4mail
    Peggy
    Regular Cherokee. Right Hand Drive. Originally from England. Pictures attached B177B1DD-500F-483C-8F3E-F44C6EB09CFF.jpgB3DDF8F5-AB72-41D3-9EDC-7AE356A3A896.jpg
  8. Nov 20, 2018 at 4:06 AM
    jeep4mail
    Peggy
    Purple wire with white tracer appeared to be pulled loose from connector
  9. Nov 20, 2018 at 2:02 PM
    Looks like it comes out of the headlight dimmer switch (marked 14VT/WT) and goes to the headlights, likely the low beams.
    Can you push it back in there? May have to take a very small screw driver or something of the like and push down in there to help seat the connector into the plug.
    1995 Jeep headlight wiring diagram.gif 1995 Jeep headlight wiring diagram2.gif
