Turn signal flashing quickly but bulb still works
Discussion in 'Wrangler TJ (1996-2006)' started by Harmo, Mar 11, 2019.
  1. Mar 11, 2019 at 9:49 AM
    Harmo
    Harmo [OP] New Member
    2006 Wrangler X
    Right turn signal is flashing quickly but light bulb still works. Should I replace bulb anyway to fix to fix the problem or is problem in the relay?
  2. Mar 11, 2019 at 10:55 AM
    Welcome @Harmo ! Check to make sure both front+rear bulbs are working properly before moving onto the flasher unit or relay.
  3. Mar 11, 2019 at 12:28 PM
    DustStorm4x4
    DustStorm4x4 Well-Known Member
    04 LJ
    Sounds like there’s a broken fuse somewhere. I’d check all your fuses.
  4. May 5, 2019 at 11:56 AM
    morzh
    morzh Well-Known Member
    Mike
    Jackson NJ
    Jeep Grand Cherokee, Wrangler JLRU.
    Usually in Jeeps this means one of your lightbulbs is bad, this is the diagnostics they implemented.
    Check all bulbs, find one that ain't working, replace.
  5. May 5, 2019 at 12:40 PM
    My right front blinker does that when I run it thru a deep mud hole until I unplug it and plug it back in. Probably need to replace whole thing with LEDs
  6. May 5, 2019 at 12:41 PM
    The bulbs are wire in series like old Christmas lights. They wire them that way so like you said when one bulb is out it makes the flasher react to quick.
  7. May 5, 2019 at 12:42 PM
    All 4 blinker bulbs are on same fuse.
  8. May 5, 2019 at 12:44 PM
    Sometimes I can smack my fender and mine will start working also.
    DustStorm4x4 likes this.
  9. May 15, 2019 at 4:05 PM
    FishinSam
    FishinSam Member
    Alberta, Canada
    1999 Gold TJ Sahara 4.0L
    Pull the plug out and disconnect. Pull the bulb.
    Clean all contacts. Replace bulb, plug in and test.
    Even a small amount of dirt or rust screws up the connection.
    Start with front bulb plug first.
    Just did this yesterday. One slightly dirty, rusty connection... works great now.
