Unknown Jeep Problem
Discussion in 'Patriot' started by Marrrq, Jul 9, 2019.
  1. Jul 9, 2019 at 3:27 PM
    Marrrq
    Marrrq [OP] New Member
    Marq
    2007 Silvee Jeep Patriot
    Recently I have been noticing i haven’t been getting the same power output when I press on the gas. To test my engine, when I got to a red light, I put the car in neutral and pressed the gas pedal all the way down. The RPM Needle maxed out at 3500 RPMs. Yet the car is supposed to max out at about 6000. Is this a transmission problem? Or maybe spark plug issue? Any help is appreciated.
  2. Jul 9, 2019 at 4:35 PM
    Welcome to the site! When you are in Neutral, the computer wont let you rev past 3500 rpm's to prevent any potential for over revving it. That's how its designed.
    Marrrq[OP] likes this.
  3. Jul 9, 2019 at 7:36 PM
    Marrrq
    Marq
    Okay thank you so much! I was getting worried.
  4. Jul 10, 2019 at 3:28 AM
    The issue sounds transmission problem.
    Lets get started with some basic ck's -
    Is there any chance the Check Engine Light is on?
    Any chance you know the type of transmission?
    Could this be a CVT, no gears just Park, Reverse, Neutral, Drive?
    Sorry its more to diagnostics than just male or female. :)
    Also welcome to the forum - :jeepwave:
    PS one of the kids has a Patriot, there happy jeepers - Out shopping for a new vehicle as I post.
  5. Jul 11, 2019 at 1:39 PM
    Marrrq
    Marq
    No check engine lights are on and the transmission is, in fact, a CVT transmission. And thank you for the welcome!
  6. Jul 11, 2019 at 2:00 PM
    The CVT trans is somewhat TEMPERAMENTAL*, suggest you discusse with a professional DEDICATED transmission specialty shop** - not AAMCO - also check with jeep as they have special programs for these transmissions.
    * euphemism :)
    ** check website for ATRA for a trans shop
  7. Jul 11, 2019 at 2:01 PM
    Welcome @Marrrq ....concur that it could be a CVT trans issue. Got rid of my Nissan when the CVT had an intermittent fail-to-move mode. Get any generic codes scanned and post them. Codes within the TCM might need to be read by the dealer.
  8. Jul 12, 2019 at 10:36 PM
    Marrrq
    Marq
    @Awrench ... So I did a little more research on the CVT Transmission and when im driving the engine is making a whining sound. Through my research its saying that that whining sound is a transmission pump issue. Is this the case? If so.. is it safe to still be driving the car with this issue?
  9. Jul 13, 2019 at 5:55 AM
    :eek: this gets expensive fast follow advice in my post #6.
